- Dec 3, 2013
- 1,849
Really nice modifications. I am thinking about the DRO Pros product for my SB 10K. The scales will barely fit and then they will cover the gib screws for the top slide. I can make it work with spacers. Are you happy with the product and was it reasonably easy to set up? I see I will need drill extension to drill holes in the cross slide and saddle? Also hard to tap those. I am torn between that and just doing something with a digital caliper like you did with the tailstock.
Coincidentally, I installed the same tach as you. I love it.
Robert
I am very happy with the EL400 and magnetic scales. I found the scales and read heads easy to get aligned using a TDI.
It's been a few years since I have been around a SB10. I'm sure you will need to custom fabricate all the mounts.
If I recall the SB13 had the follower rest mount on the back of the saddle. I'm not sure about the SB10. If so you could use those holes for the read head mount. If not a drill extension is easy enough to make. I tapped those holes by hand as there was enough room on my lathe for the tap handle, just a little slow manipulating the t-handle back and forth.
I learned on machines before DRO's and now I have no interest in having one without. I think it would be worth the effort.
