Good point. Here's what I did for mine:Don't forget a stop to keep you from smacking the tailstock base into your nice work in the Y axis!
Sent from my SM-S911U using Tapatalk
Nice solution but here in the WA rain forest I need to keep the tooling in a chest otherwise it rusts. Fighting rust is a constant battle, I should get smart and install a mini-split.I stuck my collets in a 72-hole rack that's bolted to the lid of a US General cart. The lid is fixed with angle iron; I pulled the gas cylinders. The rack is mounted with the 8-hole edge running vertically; it's a 1/64" set of collets. I labeled the appropriate rows "1/16" and "1/8"; it's quicker for me to scan a row of "1/8" to grab a 1/4, 3/8, 1/2, etc. collet.
I installed the Y axis scale and read head on the headstock side of the carriage so not an issue.Don't forget a stop to keep you from smacking the tailstock base into your nice work in the Y axis!
No need, if I move the carriage all the way to the headstock until it stops there's still 1.5 inches plus of air space in front of the Y axis scale. Nothing for it to run into, one of the reasons I installed on the headstock side.I believe he left access to the follow rest holes and could put a stop on one of those holes.
Speaking of which. Attach 1 or 2 "oil pan heaters" to your lathe - one on the headstock and one toward the tailstock end. 85-100W oughtta do it. Keeps the tool just a few degrees above ambient so when the temp drops, condensation doesn't form on the machine. When I lived in Oregon that was the one thing I did that made the biggest difference.Nice solution but here in the WA rain forest I need to keep the tooling in a chest otherwise it rusts. Fighting rust is a constant battle, I should get smart and install a mini-split.
Gene that is an outstanding idea thanks! At least it's something beyond just trying to keep everything slathered in oil. Gene for the win everyone!Speaking of which. Attach 1 or 2 "oil pan heaters" to your lathe - one on the headstock and one toward the tailstock end. 85-100W oughtta do it. Keeps the tool just a few degrees above ambient so when the temp drops, condensation doesn't form on the machine. When I lived in Oregon that was the one thing I did that made the biggest difference.
GsT
