Dropped my PM-935TS (successfully)
I had been looking for a knee mill for over a year on FBM, CL, and industrial auctions; almost every day, twice a day. A few minutes after the heartbreak of being the second best bidder on my fourth Bridgeport (4 times the 2nd best bidder), this PM935 popped up on FB 500 miles away. I had almost pulled the trigger several times on an new 935 so I was very familiar with the quality and value. After "waiting" to think it over on several FBM and CL machines and loosing them in the matter of hours, I jumped right in with a full price offer, which I felt was very fair. About 10 years old, barely used by a hobbyist, with a PM vise, a PM installed VFD, aftermarket DRO, a box of unused USA end mills, collet and rack, fly cutters, and a box of parallels that only had 2 sets showing use. The add went up and I was the first person to respond at 14 minutes. The kind seller offered to hold it for 2 weeks despite plenty of other local buyers. Seller loaded it with me with an engine hoist and 1100 miles and 5k poorer, I was in business. Wonderful seller and wonderful drive.
Step1: Getting it off the trailer was a different story and I thought posting this might be helpful if anyone else wants to give this a try. Because of the angles and heights involved, another engine hoist was no longer an option. When I first loaded the mill, I dropped it onto two full dimension 2x12"x 6'. To get it out, my dad and I jack-knifed the trailer into my shop (20 foot urban alley), ratchet strapped the mill onto the skids and wedged it between blocking, bolted an anchor into a 24"x24" footing, and used a come along to drag it out of the trailer, with ratchet straps on the backside to keep it somewhat supported. I did the next part solo, slow and deliberately.
Step 2: Next tricky part was getting it in the air without a gantry or engine hoist. I had some free 1/4"x2x2.5 angle laying around the shop. I finished through-tapping the 3/4" mounting hose on the PM's base, ran 3/4" all thread into the base, and rested the angle within drillpress-precise holes over the allthread. I then used blocks and a floor jack to get it up in the air for a few days while I could build my best conglomeration of the David Best & Firestopper mobile base that I could, sans using a brake as shown in this thread : https://www.hobby-machinist.com/threads/mobile-base-for-a-mill.53405/. The base gets me about 3" over stock height, with all the holes tapped and the M14 leveling feet going through 1/4" tubing plus an 1" of extra matereial I turned on my lathe and welded under the 1/4". I was going to have the all thread go straight into tapped 3/4" holes on the base, but I didn't want to test my luck on my measuring abilities, so it runs through 7/8" holes with lock nuts underneath the base.
Thanks everyone for your support over the last year. A special thanks to Firestopper for all the compliments I have received from friends and family on my stand, and to Mr. Best for prepurchase support and excellent documentation/write-ups on the PM935 and the design difficulties of the combined wood/metalwork in a small urban shop.
Great score! Nice work, man. Have fun & be safe.
Sounds like you got one heck of a sweet deal. Adding a power draw bar would really enhance your convenience. Ditto for power feed.
I don't mind cranking and counting with the knee, it's not too awful to live with, but I agree that the horizontal axis needs power feed. It used to be an expensive thing to upgrade and now it's not, the chinese power units aren't half bad at 1/5th the price of a high end unit.
When I dropped my PM935TV on it's face, the z axis motor was the only damage. Got a new one from PM, about 400 bux, made in Taiwan, not China. Quality is very good.
Those 935's are really nice. Some day i'll upgrade from my 728
Personal comments based on my experience: I added a Vevor knee feed unit and this has made a huge contribution to ease of use. I like it! The X axis power feed is basically mandatory, in my opinion. I spent more for a "name brand" unit, Align or such, and it's basically indistinguishable from the $125 Vevor. I've added a 4" riser and this makes a big difference in the available Z height, important for me since I've gone to Kwik Switch holders, probably about 25 of them now in different sizes, capabilities and pre-loaded tools..chucks, end mills, face mills, edge finder, tap guide, center drill, etc. While in some cases they use an extra 1" of headroom, they makes common operations like locating a part, center drilling, pilot drill, drill, chamfer, tap...fast and easy compared to changing either R8 collets in the spindle or tools in a Jacobs or keyless chuck. Also, a friend has a Bridgeport with a power drawbar and it is just not for me, and makes little sense with the Kwik Switch setup.
I wanted to wait a bit before adding any upgrades so that I could get to know the mill personally. I also ended up driving back to mill's prior owner to pick up an equally unused 1236 Eisen (same as PM's 1236T) so I have been a little cash strapped. But after putting in some more overtime I am going to venture into ER40 collets and the ER system still requires a power draw bar. My hope is it will add some of the simplicity of the Kwik Switch system. I'm in Japan right now, but I will have a Vevor X-feed on my doorstep when I get home. I had been saving for an Align but it is great to hear they are indistinguishable and 1/3 the cost.
As for a previous commenters question about the angle iron bending; I assure you that it lost no more than an 1/4-1/8" across 8 feet. The bowing seen in the picture is an optical allusion created by the panoramic photo style. Here is a better picture, holding steady for the 3-4 days it took for me to weld the stand. Also, for anyone interested, I started to design a stand for the 1236 lathe, while 700lbs less than the PM935, it still is a hefty 1000lbs. I thought I would need a mobile stand in order to access it from the rear but I found to my suprise that it can be moved by hand an inch or so at a time, creating enought room to access the rear for service and cleaning (I do understand this requires a releveling).
