- Sep 14, 2014
- 787
Jamie, the motor diagram switch doesn't match your switch. That's part of what's confusing the heck out of you. Sorry I didn't catch that earlier, I honestly wasn't paying any attention to it vs. what's coming out of the motor and then the Logan switch you do have. In the switch shown in the motor diagram you are right, there are 9 connections shown. The Logan also has nine, but the diagram only works with six as the other three are treated as a path from the input side to the output side.
I've gone through this more than a couple of times, it's almost 10, and I'm starting to go around in circles. Bottom line You are not crazy, and it's not clear how the factory switch is connecting the L1 (power). This is where I've gone through more than a few "huh" and "maybes." In a more modern schematic, center 3, #2, #5, & #8 and the lines pointed up to left, represent moving from up to down connecting to the left down, #4, & #7. But that would mean the L1(power) isn't conected. So they represent the center connections to the left in FWD (CW) and when rotated the center connections to the left in REV (CCW).
Motor wiring is (M). This is what my quick review of the factory switch (FS) tells me. Later I will try to make it clear where the M connects to the Logan switch (LS).
FWD (CW)
Logan Switch #2 is L1 hot
Logan Switch #6 is L2 Neutral
Motor #1 to FS #3 & disconnected
Motor #2 to FS #4 to FS#5 to L1 (hot)
Motor #3 is not used.
Motor #4 to FS#2 (neutral) So now we know motor #4 is the neutral in FWD (CW).
Motor #5 to FS#1 to FS#2 So now we know motor #5 is also a neutral in FWD (CW).
Motor #6 to FS#6 to FS#7 to L1 (hot) (LS#1/L1) on left side of the switch
REV (CCW)
M#1 to FS#3 to L2 (neutral) -
M#2 to FS#4 & disconnected
M#3 not used
M#4 to FS#3 to FS#2 to L2 (neutral)
M#5 to FS#1 to FS#6 to FS#5 L1 (hot)
M#6 to FS#7 to FS#9 to FS#8 to L1(hot)
To be determined how the 4 switching hot/neutral wires pair through LS#1, #3 #4 & #5 I know this is where you want to be, but at least we now know which motor pair connections are being switched from hot/neutral in FWD to neutral/hot in REV.
For the Logan Switch. Refer to my earlier for the hot and neutral connections and see if you can puzzle out what legs can go hot to hot, neutral to neutral, and the remaining ones to be switched through LS#3 & 4
I think that's where we are at. Hope this helps. LOL, 11:30 off to bed.
Now for REV.
M#5 becomes neutral from FS#2
M#.
& #6 In the switch diagram are not connected to L1 power in CW/FWD. They will be powered when the switch is moved to CCW/REV
Motor # - In the switch diagram it is connected to what is 3 in the Logan switch, the connection is swapped between they are connected to what is L1 in the Logan Switchit's connecting to
FWD (CW)
REV (CCW)
M#3 not used
Now for REV.
M#.
