Well, before you go the new motor route, can you live with the Grizzly if the Logan goes down? If you can, wire it up as I've suggested and we'll see if the magic smoke stays in the motor.
If you can't, decide if you want to go 3ph/VFD. Automation Direct is a good company, and reportedly set up Bob on the groups.io board to retain his lathe controls. Worth a call. Otherwise some Baldor motors are still US made, got mine from Zoro, Scott sells motors, or Automation Direct. Sometimes Surplus City has good prices.
Original single pulley... I was planning on modifying it. Want to see if I can make it so that I can change blades and use it to cut metal... not sure if it is possible with this model/size bandsaw. I have a set of 5 step pulleys that I was thinking of using...Sorry, neglected to give a big congrats on the WT. What is the pulley set up?
Yeah, 1/2 or 3/4 HP motor is more than enough... not looking at anything stronger than that. Thank you!P.S. IMHO absolutely no need to go over the max 3/4hp the lathe shipped with. You won't gain anything because it won't change the belt grip. Just my $.02
I will order that one next month. Thanks.The Leeson here looks nice- and would play well with your drum switch
Any motor where you swap two wires to reverse it would be easier to hook up- and preferably a motor without the thermal protectorLeeson 101650.00 Electric Motor 3/4 HP 1800 Rpm 1-PH 115/208-230 V 56C Frame | eBay
We are an authorized Leeson distributor. Spec's from Leeson;. Speed: 1725 rpm Service Factor: 1.25. Phase: 1 Output HP: 0.75 Hp. Ambient Temperature: 40 °C Frequency: 60 Hz. Current: 10.8/5.3-5.4 A Power Factor: 64.www.ebay.com
since with the drum switch you have it's sometimes necessary to bypass the protection for the start circuit
The other style of drum switch (3-phase) is a better choice for motors with thermal protectors
