- Aug 6, 2015
- 4,146
I am guessing one, but I will open that cover tomorrow and confirm.Does this motor have 1 or 2 capacitors?
Why?
It has a capacitor mounted on the outside under a cover. I just need to remove the cover to confirm that it is only one in there.I've only seen them externally mounted with a small cover. I saw one. If you don't remember seeing two then there's probably only one. If we can't match wire colors, should be straight forward to trace them.
I deleted a schematic that was close because I'm pretty sure this is what you need.Okay... need help to correctly wire the motor so that I have Forward and Reverse.
This is the motor I have:
Opening the area for the wiring in the motor... this card was inside.
This is the Drum Switch I have:
Let me number this to make it easier...
This is what the Owner's Manual has for a diagram:
Wiring:
View attachment 495554View attachment 495555
As mentioned before, at this moment, if I move the knob to F or R the motor turns forward...
I will search for the forum member that offered help... I was not ready back then but I am ready now to finish this task.
