I changed the order of the build so I could first install the front cog belt pulley and make sure it ran true. Then I decided to make up the flywheel so it would be easier to turn the engine over after installing the o-rings.
I had an ugly piece of 4" round steel that I had tried to use on a different model a couple of years ago for a flywheel but it wasn't big enough for that model I think it may just work fine here.
I started by digging out 0.200 from both faces to thin it down on the lathe.
Then over to the mill to make some lightening holes to improve the looks.
The center flange was from a previous build also and required the center hole to be enlarged to fit this crankshaft.
Painted both pieces and left them to dry overnight.
Installed the belt pulley and the flywheel today.
What do you think?
Should the center taper lock flange be a different color?
This shows how I cut the grooves in the pistons for the o-rings.
Pleased to say all cylinders hold a vacuum for at least 30 seconds.
Thanks for looking
Ray
