- Oct 13, 2014
- 8,690
Yeah, I think the end of the spark plugs become the points, they make contact with an electrode at the point of ignition.Do the spark plugs rotate? And if so, how would that work???
I found the original Popular Science (not Mechanics) article that triggered my obsession at 12 years of age. It starts on pgs 62-64 and on pg117.All right guys I have done some more research into an internal combustion version of the rotary vee engine. I have watched all the videos and tried to make some sense of the NASA report.
I am not an engineer but I can see one very real problem.
Lets look at one of the piston rod assembly. This one rod will have a firing or explosion at each end of its length at exactly the same time. If the amount of energy is not identical at each end the rod the rod will tend to bow up and bind in the cylinders. From past experience with multi piston engines each piston does not have the exact same amount of force or horsepower. Getting a fuel air mixture to be exact in each cylinder is above my pay grade.
The engine is of a two cycle design of which I have very limited knowledge but that may account for all the smoke generated in the video. To lubricate this engine the fuel and oil mixture will probably be in the 10 to 1 ratio or even lower.
There are many other reasons I am not interested in building the internal combustion version of this engine at this time but will continue exploring a air or steam version.
It may turn out to be a fun project.
Ray
That is very kind of you Tom thank you.If anyone could pull it off it would be you Ray. Your skills are amazing
