Thanks Chris
I installed the liner and drilled and taped for the intake valve, the exhaust valve, and the spark plug.
I have given this a lot of thought as to just how I am going to support the upper piston through out it's up and down travel. It also has to be kept from tilting sideways and turning.
This is what I am going to try first and it may not work, or it may wear the sides of the slot or bind up. We will just have to see.
1/2" end mill centered on the cylinder bore with a depth of 1.25"
Well that slot worked out very nicely.
The lower part of the slot extends into the cast iron liner.
So here is the upper piston, connecting rod bolt, cross bar and brass side retaining stops.
I wanted the connecting rod to be adjustable in order to be able to adjust the piston and in turn the compression ratio.
It moves smoothly now but the true test will be when the outer connecting rods and the o-rings are installed.
Thanks for looking
Ray
