- Feb 2, 2014
- 1,185
As you can see I have raised the engine up 1" to allow for these new 6" flywheels. The gas tank was moved up also and the ignition system was rearranged with an on/off switch.
It seems that every time I make a crankshaft I try to make it longer than I need so there won't have any problems later but I still run out of room on one end or the other. Same problem here on the cam drive side but I was able to move the cam and the drive over to make room.
The new flywheels have made an even bigger difference than the piston and rod did. The combined changes to the engine are getting closer to the way I want the engine to run.
There is one more thing I want to do before I make another video of the engine so stay tuned.
Thanks for looking
Ray
Thanks for looking
Ray
