- Nov 24, 2014
- 3,411
I continue to be amazed at the rate of your build.
I'm wondering if the spark plug and valves have 3 independent ports or are to be implemented via a single tapped hole.
IIUC, you intend to use O-rings as piston rings. You might want to consider using X profile rings to better resist "rolling" an O-ring.
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
www.mcmaster.com
