Straight 6 Cylinder Engine
Started on the other side of the cylinder block for the cylinder liners. After drilling 1/2" holes I next went with a 1" drill Bit.
Then with the boring bar out to 1.250 and a 0.100 larger lip on top for the liner to rest against.
I could see the connecting rods were going to hit the insides of the block so just cut out the sides.
That fixed that.
Thanks for looking
Ray
I have decided to make the engine block water cooled. I have one other model I had built that uses a radiator and water pump so active water cooling is not entirely new to me but will be another challenge.
Milling out a 2" deep section for the water jacket.
When I started with this aluminum block it weighed in at 8lbs and 4 oz.
After the diet it now weighs 4 lbs 11.5ozs.
I also made a good start on the cast iron cylinder liners.
These will be cut in half to make the 6 liners.
Thanks for looking
Ray
Working on the cast iron liners today.
I cut to the OD to size leaving a center section larger for the lip in the block. Then I cut them in half and drilled the center out to 7/8".
Bored the inside out to 1".
All six in a row.
I glued the liners into the block using high temp gasket maker and clamped them in place.
Thanks for looking
Ray
Saw a new video in your channel and had to search for the thread here. Cool!! :cool:
Thanks wachuko great to have you along.
Ray
I decked the cylinder block to get everything nice and level again.
It looked so pretty I couldn't help my self but had to paint it.
Used Allis Chalmers orange.
What do you think?
Also cut out 6 rods on the RF31 clone CNC.
All in a row.
Thanks for looking
Ray
Thanks Chris
Working on the connecting rods today.
Milled out slots for the 4-40 rod cap bolts.
Drilled the holes for the 4-40 screws.
Always trying something different I ran across these from McMaster Carr and will give them a try.
"863iron-copper bearings are also known as Super Oilite® bearings"
I cut them to length on the lathe and loc-tite them into the rod end.
I will let the loc-tite setup over night before sawing the rod caps off.
Thanks for looking
Ray
Looks like you used 1/4" material for the rods. Am I right?
