- Dec 18, 2019
- 7,654
I did level a level that is 10x more sensitive that a 98-6. Finding the level line within the range of the level is a lot harder! If you go in 5 degree increments, you might find it. Using 15 degree increments, you won't find that line, or at least that is my experience. The more level the plane, the easier the level line is to findYou find the level line on a generally non-level surface with your uncalibrated level by rotating it until the bubble is +/- an equal amount from center when flipped. No need to know where that level line is before hand.
Of course, you do have to start with a flat surface that is at least somewhat level, or else your bubble will be out of range in most orientations. But with the 6" 98, this is not very hard (more sensitive levels are harder). It only takes a minute or so to get very close (I've tried it). After that, it's just a matter of how obsessive-compulsive the tool's owner is.
Also, checking the Starrett 98, the slotted screw thread cannot be used for adjustment. It just creates a pivot point. It probably shouldn't be screwed down too tight, either, as while that end of the level rests on a ball-shaped pivot, the bottom of the screw's head is flat. I'm still a little puzzled about this configuration. But on the 98, you apparently do have to use the nuts.
At least you have the sense to get a level that isn't too sensitive. Alas, I didn't, and it took me quite a while to get it to converge. My level could tell if someone entered the room, 10 or 12 feet away. If I stood on one side of the level or 90 degrees to the level, the readings were different.
