@SouthernChap
I had thought of fitting a DRO kit, in the abstract sort of maybe, maybe not way, and actually devised ways to fit one with the least possible interference or footprint. Still need to look at the best head unit & scales combo though.
As to space constraints, are you referring to underslinging a connecting plate from the apron to the reader head of a DRO on the rear of the bed on the Mini? I figured that was the best way to do such things in a "limited space" environment such as what I have, hence the "plate across the webs" to stop swarf dropping and collecting on the top of said plate.
As for the DRO encoder for the carriage, I have a plan to mount one that is none-too-difficult and can be done without interference to other things. (I have something in mind that fits between the underside of the ways and the top of a DRO scale, so need to keep that space clear)
Not sure about the cross slide DRO scale, nor indeed about whether to fit one one to the compound, but eh, I will look further into that once the lathe is rebuilt and running, which is not too far off now thanks to slowly ticking of the jobs over a period of time.
I was actually thinking, for some odd reason, of fitting a DRO scale to the 5x4 milling slide I have. Probably won't, but who knows? I do use it more than I thought I would and it would be handy to have.
