- Aug 19, 2023
- 1,342
Don't understand you saying that you won't need a lead screw. On my ELS, the carriage position is changed via the lead screw and the half nuts. Basically, I have disconnected the mechanical linkage between the lead screw and the spindle. Then added an encoder to the spindle and a stepper motor to the lead screw. The linkage between the spindle and the lead screw is now electronic. What are you doing?
@WobblyHand
I never said anything about not using the leadscrew. What I said was, and I quote
With an ELS kit, I doubt I will use either leadscrew for screwcutting using change-gears, but the option is always going to be there.
