- Jun 22, 2023
- 676
lol did you read my thread i had the same problem and they discounted my lathe $180 + tax to compensate me. yes i also drilled out the 4 jaw chuck and got great results as i explained in my thread the dividing head that i bought uses the same bolting pattern and the regestere is exactly the same so i used it as a guide to drill 2 holes to turn the 4 bolt pattern into a 4 or 3 bolt. the adapter plate that i linked, i think you can use to do the same thing ie use it as a template and not need it on the lathe.Thanks for that @dabear3428 . The only problem with adapters/spacers is they extend the chuck further away from headstock bearings and amplify any runout. I also saw the video on the same post to the guy who installed a Vevo independent four jaw chuck by drilling out the new chuck to accept three bolts. I think I might go this route.
As an aside did your lathe come with a cast iron compound slide as shown in the eBay image at the beginning of this post? Mine came with this rubbish hollow aluminium compound slide:-
To rotate it you have to wind the slide nearly off to access the two bolts attaching it to the cross slide. It has no quadrant to check the set angle and it would be better if the compound slide gib and adjustment bolts were on the opposite side of the compound slide as there would be less likelihood of the slide twisting as the tool bit into the workpiece. That said I have found a cast iron compound slide assembly on Aliexpress that looks identical to the eBay image. I need to sort out the chuck first before I attempt any more changes
can you pass on the link to the compound slide, i bought 1 made from cast iron but it will need a spacer to work. also i'm working on a solution to the angle adjust issue just have a few projects in the way before i get back to it.
