- Sep 14, 2014
- 738
Stu, my apologies, I shouldn't have answered pre-coffee. Yes, my bad for not making it clear that isn't the interface I'm talking about. The backing plate/chuck interface needs to be a press fit of the plate "spigot" into the chuck counterbore or in the words of LaBlond: " . . . rough turn out-side diameter 1/32-inch above diameter of counterbore in chuck. Also counterbore tapped hole at 45 degrees to 1/8-inch across flat; next, take finish cut off face of chuck plate.Their would be a risk of movement if the chuck register isn't a tight fit to the back plate I would of thought. Unless you did the "buck chuck" style screws to lock it in place.
If you had no interference fit you would need to indicate it in as you tightened the chuck bolts to the backplate.
Stu
Caliper counterbore of chuck and transfer size to outside mikes. Finish turn OD {of the spigot} to fit counter-bore allowing for a slight tap fit."
1/32" into the chuck body counter bore wit h a "tap" fit.
