If you have the Harig manual, there's a procedure for leveling the grinder. You definitely want the machine level. Besides how it affects the grind, the oil system will thank you. There are "dams" at the ends of the V and flat ways, and if you're much out of level, oil will spill over and you'll not only have an oil system working improperly, you'll have a mess! Also make sure the four rubber isolation pads in the corners between the main casting and the base cabinet are in good shape.
If you don't have a manual, contact Jim here.
https://harigtechsupport.com/
He'll email you a free one, if he has it in PDF form. There's a chance that he worked on your grinder when it was built. A wealth of knowledge, and a good source for hard to find parts. They may not be cheap, but he has them.
