Firstly, I hope you are feeling better.Again, joe pie is talking about an integral head stock lathe. Things get more complicated when you have head stock alignment to deal with as well as twist. If you go chasing what you think is twist and the issue is also headstock alignment, you can be chasing your tail.
If absolute leveling is not where its at, why use a more accurate level.
I was hoping someone had experience dealing with sag, twist, AND head stock alignment.
Need following this discussion and you make a ton of sense. So there’s no way to actually indicate the headstock in? You have to turn a test piece?Firstly, I hope you are feeling better.
A more accurate level doesn't just show what is level, it shows how much out of level it is. If your bed is out of level the same amount up and down the bed, then bed twist isn't an issue.
Adjust the bed using a precision level to minimize twist, then align the headstock so that the spindle is at right angles to the bed. You check that by chucking up a large flat workpiece and facing it off. Run a spring pass to make sure flex from tool pressure didn't undermine the test. Check the face for flat using a straightedge and feeler gauges, but that is accurate only to the thousandth. Is the faced-off part dished? High in the center? If you have a good surface plate, sweep the part after facing--even if one side of the test part is higher than the other when resting on the plate, the center should be exactly in between the two edges as you sweep it. Use a tenths-reading dial test indicator. But you can save that for the final adjustment--you can get it to the thousandth using a straightedge and feeler gauges without removing the test piece from the chuck.
Adjust the headstock until a facing operation produces a truly flat surface when facing--that's the only job of headstock adjustment. That ensures that the cross slide is at right angles to the spindle. After doing that, check that the tailstock is truly aligned with the spindle by pinching a razor blade between centers. If it pinches at right angles to the spindle and not cocked at an angle, the tailstock is aligned. Adjust the tailstock until that happens. If it's off a little vertically but not horizontally, that's probably the best you can do.
Then, check to see if it's turning tapers using the two-collar method (or use a certified test bar like the one from Edge Technologies). If it is, adjust bed tilt slightly, realign the tailstock, and check it again. After all that, face off something large again just to make sure you didn't undo anything related to the head alignment.
The head alignment is only for making sure that the cross slide moves at a perfect right angle to the spindle, not for curing tapered turning. It will cause tapered turning if out of alignment, but fixing the tapered turning with the headstock alone will likely leave it out of square with the bed.
TL;DR: Level the bed with the best level you have. Align the headstock so that the cross slide is square with the spindle and prove that by the flatness of a faced part. Align the tailstock to the spindle using the razor-blade test. Check for tapers using the two-collar test. Adjust tilt and realign the tailstock and repeat until the lathe doesn't turn a taper. Check again for the flatness of a faced part--if that was lost, do it all again, but you'll be a lot closer this time.
Rick "be glad you have an adjustable headstock--most of us don't" Denney
I have a used enco 13×40 lathe. As is common with asian lathes, the head stock is adjustable. When I first moved the lathe into my shop, I leveled it with a make shift plumb bob level and it cut pretty good for a newbie. Then one day, I crashed the carriage into the headstock and it began cutting tapers.
I did a lot of reading about leveling a lathe and found almost all discussions related to leveling lathes with fixed head stocks. My concern was that I believed I shifted the head stock alignment when it crashed since its unlikely that the leveling was impacted.
I read a post that suggested to face a large diameter disc and check the face with a test indicator to check head stock alignment. As the test indicator moves across the face on the back side of center, it will show misalignment. I aligned the headstock with this method with the largest diameter I had, about 4 inch, and the lathe cut pretty good again.
Now my projects and skill require more and more accuracy. I want to properly level the lathe and check alignment of the headstock more accurately. I plan on facing a much larger diameter disc to check head stock alignment, but was wondering if I should invest in a machinist level to start the process on the right foot. The Starrett 98-12 is accurate to .005 in 12 inches. Is this the way to go or is a different level required? Is a 98-8 or 6 acceptable as the are not as pricey? Should I level first, adjust headstock next, and then cut test bar for taper indication?
Thanks for any input here.
Turning a test piece is always the final arbiter--that's what lathes are for.Need following this discussion and you make a ton of sense. So there’s no way to actually indicate the headstock in? You have to turn a test piece?
Right. Whatever the lathe machines will be square with the tool, because the tool is what makes it so. If the facing operation creates a high center (gaps under a straightedge at the edges), the headstock is pointing the spindle a bit towards the far side of the lathe bed from you. If it creates a dish, the headstock is point the spindle a little towards you. If you measure dish at the center and it's, say, 0.004, then put a dial test indicator on that center spot and adjust the headstock away from you enough to move it 0.002. If a straightedge touching all along the near half is leaving a gap on the far edge of 0.004, then adjust the headstock towards you enough to move a dial test indicator at the far edge back 0.002. Then, make another skim cut and measure again. When whatever gap is under a thou, switch to your tenths-reading indicator (or declare it good), but at some point you won't be able to move the headstock in small enough increments to make an improvement, and you'll overshoot. That will tell you where good enough needs to be on your equipment.This is great info. Exactly on point. I will follow the order of checks and adjustments you suggest.
Any advice on the recommended diameter to face off for a 13x40? The post I read about facing a plate for headstock alignment said that the test indicator traversing across with the cross slide will read zero from near side to center and will indicate increasing or decreasing from center to far side depending on the direction of misalignment. Had to draw a diagram of a twisted headstock to wrap my head around that one. In essence, you will have a cone type of taper with the side nearest you square with the ways. Draw out a sketch and you'll see what I mean.
