I am not convinced that bed twist can have that much of an effect on a 2 collar test when the part is between centers. Consider if you have a long part between centers and the bed is twisted. You cut or measure the right collar with the apron all the way to the right. The apron will be mostly sitting on the twisted part of the bed so the distance from the center to the cutting tool will remain almost the same regardless of the bed twist. I can see where there could be a small change with twist but nothing like you can get by adjusting the sideways location of tailstock.I do a two-collar test using an Edge Technologies test bar, between centers. They call it a tail stock alignment bar, which it is, recognizing that tail stock alignment is affected by bed twist as much as the lateral adjustment.
Tailstock Alignment Bar 27-000
The Tailstock Alignment Bar by Edge Technology is used to align the tailstock to the headstock. Accurate alignment is critical to eliminate any taper in work pieces that are supported by the tail stock. Our Tailstock Alignment Bar makes the process of tailstock alignment fast, easy and accurate.www.edgetechnologyproducts.com
Rick “learned that the hard way” Denney
Try it and let us know.I am not convinced that bed twist can have that much of an effect on a 2 collar test when the part is between centers. Consider if you have a long part between centers and the bed is twisted. You cut or measure the right collar with the apron all the way to the right. The apron will be mostly sitting on the twisted part of the bed so the distance from the center to the cutting tool will remain almost the same regardless of the bed twist. I can see where there could be a small change with twist but nothing like you can get by adjusting the sideways location of tailstock.
It seems like any bed twist would have more effect on diameter between the 2 collars.
The more conventional way to check headstock alignment to the bed is with a test bar which allows checking along the length in both the vertical and horizontal planes. The test bar is checked each time it is installed by rotating it and doing measurements only at the midpoint between the highest and lowest reading. Even a relatively crappy test bar can be used. Tailstock not used for this. Bed si leveled first. Rollies Dad is an example showing a precision test bar and taper is not necessary but a uniform diameter sure makes it easier.
I am not suggesting your way is wrong, do whatever makes sense and works for you.
Bed twist isn't linear. It's constrained on the headstock end by the headstock being clamped to it. The cutter is at various positions between the tailstock and the headstock, so the error will vary. Most of us with old lathes are already having to deal with a dip in the ways close to the headstock.The carriage rides on the ways, along with the cutter. If there's twist, even if the stock is perfectly aligned between the head stock and tail stock won't the cut be affected by the twist?
