- Jun 15, 2017
- 585
I made myself a tool chest attachment to hold belt grinder tool arms, and then I tried to paint it. I used Rust-Oleum primer and farm implement paint in spray cans.
On the first try, the paint came out rough. I started wet-sanding it so I could spray it again, and I found a bunch of surface imperfections in the paint and metal, so I stripped it with an angle grinder and started over. I painted a small area that won't be very visible. The paint still looks rough.
Should I give up on spray cans? I've gotten beautiful, glossy results from the brush version, but it's not much fun to apply. Does anyone else here get smooth finishes from spray cans?
I held the can at the proper distance from the work while spraying, so that's not the problem. The humidity is very high this week. I don't know if that causes problems.
