This has never been clear to me if you want chips or spirals. Many on this forum seem to indicate that proper cutting results in chip breaking. However I do find the spirals to be a thing of beauty! Others seem to consider them a hazard. I suspect that some of the chip breaking is due to friction and binding between the tool and the cut piece (chip) and that some of this friction and breakage is removed due to some lubricants. Some chip breaking tools seem to bend the spiral sharply effectively breaking the spiral by bending it to induce stress/strain.
If you have done much drilling with a two, or more, flute bit, you will notice that sometime, but not often, you can get two spirals at the same time. One comes from each of the flutes. A thing of beauty! I interpret this to mean two things. 1) The bit is properly sharpened such that the two flute cutting edges are near identical! 2) The feed rate and rpm is adjusted such the each flute is cutting the same amount of material. If the two flutes are not sharpened evenly and/or the feed rate is too slow, then only one edge cuts and the other just rubs generating frictional heat and wear. ( For me, in hand sharpening a drill bit it is almost impossible to get both flutes to be exactly even, the same. This is especially true for smaller bits. So when I am calculating my feed rate I commonly assume that there is only one flute cutting! )
At a conference I attended, I wound up having lunch with a couple of research physicists who worked for Gillette. During our conversation I ask them to explain cutting to me. What is it that happens at the molecular level? How can I make a tools edge so sharp that it slices between the atoms to separate them. While there are models and theories, their response was that "no one really understands this!" What I know is that a new razor blade does not pull at the whiskers while an old one certainly is not as pleasant. By the way, is shaving cream a lubricant or is it just to allow water to soak into the whisker, swell it and to soften it up for cutting?
PS. Sometime you might want to try to measure the thickness of one of those spirals and see if it agrees with what you thought you were going to be via the feed and speed calculation.
Dave
Dave
