- Jun 12, 2014
- 4,996
PM1236T has a Norton open gearbox, so by its nature it is a complete loss system and drips into the pan. An important reason to use an oil resistant sealant around the mounting bolt holes and pan when mounting your lathe into the stand. I have done a number of pump oilers for this gearbox that uses a manifold system. People put drip pans under the open gears. They rarely have issues of oil leaking from the headstock, I did have some carriage seepage through one of the shaft plugs. The 136T/1340GT are reliable well made lathes at the price point.
Regarding the closed gearbox reassembly, I would do it dry until you have it worked out as to an assembly procedure. PM may be able to give you some guidance. A bit challenging on reassembly but you may be able to map out the gear position for each knob and work backwards so start out with the S I for the right two knobs, then work on the A position, and then 1 position on the left two knobs. Always worthwhile to take lots of photos of everything when pulling things apart.
