- Dec 15, 2018
- 818
What you have would work as is David. There's no need to clamp the torch. I incorperated a thumb screw to fix it but have never used it. Gravity is your friend. You do need to hold the cable up above the table so the cnc doesn't need to drag it. I use the overhead crane, the torch can swing in the mount as it moves around.
Greg
Greg
