CNC plasma cutter build
All wired up and ready to go. Just need to wire in the torch controller.
Awesome, and great job on a very cool project!
Very inspiring!
Thanks for bringing us all along.
-brino
Congratulations !! Hope the first cut wasn't the deepest. lol
Greg
Greg
Hah!
Naw, Rod and I are tight. :D
It was just 22ga. I’ll try some thicker stock when I get the slats for the water table done.
Excellent project.
The cutter is starting and running OK without an active Z axis height control, yes?
There seems to be some error between when the cutter is moving away from the camera vs toward camera. I noticed what looks like (nearest the camera) a flat (cord) on the round hole and the two short segments of the square don't converge. Are those intended or mechanical backlash or software tuning? My question is, if those observances aren't intended, where do you expect to implement the fix?
