- Aug 19, 2023
- 1,414
You must have had better bearings than most other 7x owners did. The bearings in all the 7xs I'm aware of, are single race, deep groove ball bearings; not really suitable for the forces on any lathe that's potentially going to be turning anything harder than aluminium or free machining brass.
I had my original bearings in place for not that long and they developed axial and radial play.
Arc Euro Trade, for all their faults, have pictorial PDF guides to replacing the bearings on a C3 or an SC3 with tapered roller bearings and angular contact bearings respectively.
It's hard to think of anything more critical to the 'health' of a lathe than the bearings the spindle runs in, so whilst I might differ with @GrifterGuru regarding the priority of some things on his list, I'd agree with him about getting good bearings around the spindle.
@SouthernChap
Everyone views certain needs in a certain priority. My views differ from yours, just as yours will differ from somebody elses, mine included.
TBF, I initially only replaced the bearings on the SC3 under warranty. Then carried out the two half-nut conversion, followed shortly afterwards by the complete replacement of the apron for one with a full and proper dovetail for the half nuts and a bearing for the handwheel gear.
Other than that and finally fitting a 4" flange spindle (inc new A/C bearings) along with swapping the plastic gears for metal ones, leaving only the plastic leadscrew gear as a "fail safe" should it ever be needed, the lathe could be looked at and considered as a better spec'd stock machine, which, I suppose, it actually is.
Still, I am looking forwards to getting the 7x I am rebuilding finished!
