David will please excuse my off topic question in his thread.
@f350ca , Regarding the use of the shaper to make your racks; can you describe the sequence of operations to create each tooth form?
Did you finish a single tooth form/root (feed table up?) then traverse the pitch dim to create the next tooth form/root?
Or, did you set the traverse auto feed to equal the pitch dim so you could work many teeth before re-indexing the stock on the table?
Or, what ???
Love your work.
