- Dec 26, 2015
- 2,154
I have not seen any, nor do any show up searching. The ER40 collets are much shorter than the 5C, and since they are designed with staggered slots from both ends and have a 1mm clamping range, every ER collet I have seen is made from some kind of spring steel that's very tough material. An emergency collet needs to be soft enough to machine to the desired bore or profile. Intuitively it seems to me that the springiness of the steel required to function well with the ER taper angles would not be a suitable material for modification. Of course, this is all just my speculation.Are there emergency ER collets?
That said, I do believe it would be possible to machine an inner insert that fits in a larger standard sized ER collet, has a more narrow clamping range, and made of a material that could be machined to fit production parts including a depth limit stop. Kind of a collet within a collet. Again, pure speculation.
Each collet type has it's own set of advantages and disadvantages, and 5C with a quick-release chuck is probably better for production work. But if your need is variety/randomness of clamping diameters with the least number of collets for prototyping and one-off work, ER40 is probably a better choice IMO. And then there's the tradeoff of how much insertion is required to attain a specific TIR tolerance.
