If I recall correctly one needs a set of gears/dials to do full metric threading on a metric lead screw. These may not be included in the purchase. Pretty sure a single dial doesn't cover all the metric threads. That's about all I know on the subject, so don't quiz me on it. I
My metric lathe has a 2mm lead screw, and I am currently working on acquiring all the thread dial gears made for my lathe. They are 28, 36, and 40 tooth gears. I've been reading up on metric thread dial information and of course only now I see how much more complex a thread dial is on a metric lathe.
I have never spent much time thinking about what external and internal gears one might need to build a metric lathe. A 2mm/thread lead screw in TPI is 25.4/2 =12.7 TPI. So it would appear that the lead screw is just playing the role of the 127 tooth transpose gear. My PM1440GT normally comes with a 8TPI lead screw.
The Standard Metric thread values are: 6., 5.5, 5.0, 4.5, 4.0, 3.50, 3.00, 2.5, 2.00, 1.75, 1.50, 1.250, 1.00, 0.80, 0.75, 0.70, 0.60, 0.50, 0.450, 0.40, 0.35, 0.25, 0.2 .
Since the Imperial to Metric Transpose gears are normally 120/127 and the new lead screw TPI is just 127/10 this would imply that if the lead screw were changed to 12.7 TPI (2mm/thread) and the transpose gear was changed from 127 to 80. It would be the same as moving the 8TPI lead screw count to the transpose position. However, the 120 portion of the transpose gears is too large to cover the standard metric thread value. It should be change to 60 rather than 120. This introduces a factor of 2 in the string of gear ratios being multiplied out.
So in my Excel worksheet I changed the set up of the PM1440GT to have a lead screw pitch of 2mm/thread (12.7TPI). Then I changed the Transpose gears to 60/80 rather than 120/127. Then I ran the program using the standard set of PM1440GT external gears. I did not check to see if all of the external gears were required, but with this arrangement all of the standard metric threads are possible. The largest Pitch that resulted was 24.64286mm/thread (1.03072 TPI), which would probably never be used. The smallest pitch that resulted was 0.17391mm/thread(146.0526 TPI), which would probably never be used either. However, it is obvious then that rather than using 60/80 as the exchange gear one could use 30/80 or even 15/80 which result in lower pitch values by factors of 2 or 4 respectively. There is probably little value in this except that it would probably result in more possible gear combinations of achieveing the 0.2 pitch.
A list of the lathe settings to obtain the EXACT standard metric Pitchs is attached. Note the pitch values are highlighted. There are far many which are close approximations to the exact values. This was done twice. Once for the 60/80 transpose ratio and once for the 30/80 ratio. Note in the table when the notation is Letter&Letter, such as N&S this means the gear at the excel columns N&S can be any value that is the same for both columns. In the case of N&S the S value is 60 in one file and 30 in the other file.
My conclusion is that by changing the lead screw to 2mm/thread and replacing the exchange gear's ratio to 60/80 or 30/80 or 15/80 one can generate all of the standard metric pitches using the Standard PM1440GT gear box and supplied external gears. One gets multiple possible gear and lever arrangements to achieve each the standard metric threads.
Dave L.
PS. An eariler version of my Excel workbook is at:
Nov. 6 2023 Excel workbook file name: TPI_ManyLathesRev1 NB06_0054.xlsm
