too right! I just got given a bunch of alu and steel (CI?) disks from the Geo department that they charged with diamond dust for grinding and polishing rocks, so that's another project
Just the use for the motor off my drill press when I put a treadmill motor on it..
IT RUNS! There's a bit of vibration and humming coming through the bench, so I need to work on the isolation a bit more so no vid, but here are some pics.
Slowest speed without backgear - using back gear gets me down into the 10-20 range, although the tach doesn't pick up very well below 30rpm.
max speed in that gear, so there's considerable head room if I use one of the larger pulleys if I ever need it (or have the cojones)
motor set up - the motor pivots on that wooden block so I can fine tune the pulley height. Didn't actually mean for it to work that way, I just drilled the holes in the bench from the wrong side of the block
Tach pickup. I should make something a bit more robust but this works just fine for now
woohoo! Thanks to everyone for their help, it's been a fun project and I am totally pumped by being able to vary speed on the fly. Have to work up a simple chart of speed/diameter/material/cutter to laminate and stick to the splash guard.
One thing I have learned though is the merits of right angle spade connectors - it was a real effort to get the front on that box, especially with all the PITA 14 gauge wire in there.
