Just kidding on that one, really.
However, in all seriousness I have had some parts running on CNC screw machines where nailing down the hole size was troublesome, SOme L&I reamers cut oversize, some under, and I often found myself trying several sizes up & down to get one cutting the diameter where I needed it. This was always in applications requiring tolerances tighter than .0004" total variation.
Here's a way to add or subtract a couple of tenths.
take the shank of a drill or a piece of drill rod tha just fits the goove of the reamer. hold it perpandicular to the edge and firmly draw it from back to front. Once for every land.
This raises the wire edge and buys a couple ot tenths. You can also decrease the edge by doing the same thing on the outside edge, just keep the bunisher parallel to the cutting edge.
This works for straight shank reamers only.
in an emergency you can reduce the diameter of a reamer a couple of thousanths or more by drilling a hole in a piece of hardwood the same diameter of the reamer. Split the hard wood to bisect the hole and coat the hole with lapping compound. Chuck the reamer in the lathe and run it in reverse for a RH cutting reamer. Run the loaded block up and down the cuttung edge a few times an mic it to check size.
Remember. The finish on the reamer is the finish in the hole.
