- Jan 4, 2021
- 2,704
Thank you!
no not really.
And while not a really cheap bargain, it’s still a hell of a deal.
Thank you!
no not really.
OK. I'll add fuel...Help somebody: I can’t find my copy of “THE SIGN!”
There was a female flare fitting on the bottom, and the hole does have a threaded insert.I'm betting it's a jigging plate, and the grooves are the top. The hole maybe for a rod, does that insert have threads?
The bottom roughness is of no consequence if it sits on three points of contact. It can be easily leveled.
Just guessing.
That's a lot of inserts! Especially parting inserts. I've only used HSS blades for parting. Are the carbide parting inserts that good? Do you part stainless steel? That's the only material that has ever given me grief, everything else just cuts. It seems you ought to be set for a while with inserts.Bit of an "ouch" moment of £565 GBP ($738.62USD / $1011.73 CAD) on this bill, but replacing stock and adding new cut-off/parting/grooving tools could not be put off any further.
Full list is as follows
10pcs SP200 (GTN2) Grooving Parting Off Inserts £14.99 10pcs MGMN200-G NC3030 (GTN2) Parting Inserts £11.99 10pcs 11IR AG60 H01 Aluminium Internal Inserts £14.99 10pcs MRMN200-M NC3030/PC9030 Round Inserts £14.99 10pcs RCGT0602-MO H01 Aluminium Inserts £14.99 10pcs MGMN300-M NC3030/PC9030 Parting Inserts £14.99 10pcs CCGT060202-AK H01 CCGT21.50 Aluminium Inserts £14.99 10pcs SP300 NC3030 (GTN3) Grooving Parting Inserts £14.99 10pcs MRMN300-M NC3030/PC9030 Round Inserts £14.99 10pcs MMT 11ER AG55 UE6020 External Inserts £13.99 10pcs DCGT070202-AK H01 DCGT21.50 Aluminium Inserts £13.99 10pcs SP200 (GTN2) Grooving Parting Inserts £14.99 10pcs 11ER AG60 H01 Aluminium External Inserts £14.99 10pcs DCMT070204 US735 Inserts £7.99 10pcs MGGN200R-8 H01 Parting Inserts Aluminium R/H £19.99 10pcs MGMN300-M H01 Parting Inserts Aluminium £14.99 10pcs MGGN300R-8 H01 Parting Inserts Aluminium R/H £19.99 10pcs DCGT070204-AK H01 DCGT21.51 Inserts Aluminium £14.99 10pcs MRMN300-M NC3030/PC9030 Parting Round nose Inserts £14.99 MGEHR1212-2 Parting Grooving Lathe Tool Holder 2mm £12.99 MGEHR1212-3 Parting Grooving Lathe Tool Holder 3mm £14.99 1pc Carbide Insert Boxes + Lids - White £1.99 5pcs Carbide Insert Boxes + Lids - White £4.99 10pcs Carbide Insert Boxes + Lids - White £13.98 19/2 REPLACEMENT INDEXABLE PARTING BLADE 19MM £19.99 10MM PARTING OFF SYSTEM CUT OFF TOOL BLOCK BLADE + 3MM £36.50 Q TYPE Parting tool 12mmx2mm (GTN2) £26.50 Q TYPE Parting tool 12mmx3mm (GTN3) £26.50 8pc 250-001 Tool Holder £80.00 4.2x7.4mm Counterbore £6.11 40mm x 20mm x 300mm Aluminium Plate £18.68 50pcs M5x.08 12.9 nuts £5.02
I've never experienced having to pay for the insert boxes, wow, things are different across the pond.
Good idea on the color coding.I buy bulk precisely so they DO last a while. This little lot will last me quite a time. Makes sense to have it on-hand when I need it, than have to wait around on a specific insert type to finish a job. Been there, done that, not doing it again. Once was enough.
As for the stainless inserts, I find they hold up better to non-stainless steels as well as other materials better.
Found that the Aluminium inserts (CCGT et-al) are excellent with silver steel and the Stainless inserts are great on plastics.
Parting stainless... Never had any problems with that. Normal steels? different story!
As for the boxes... That is a concious choice to buy white boxes. I separate my inserts into Red / White /Blue boxes depending on what the insert type is. Normal inserts (CCMT et-al) go into white boxes, Aluminium inserts (CCGT et-al) go in blue boxes, Stainless inserts go in red boxes. Makes it easier "at-a-glance" in the drawer to see which are which.
