Received my "undersize" ER32 collets from SHARS: they look good, have the SHARS logo (and size range!) engraved on each one. I found a larger box and now have both the under- & over-size ones together:
Now all I have to do is make a label for the box lid (yes, the collets are marked, but the marks are tiny).
Used a 1-1/4" OD SS tube with the end round to a bevel to push the holes in a piece of rigid foam (I have accumulated a handful of these tube/punches over the years - they work great):
I know exactly what you mean by the marks being too small. I bought a set of share er-16 from a pawn shop and I need a magnifying glass to confirm they were Shars. Those er-32 look great. Did you buy them through amazon or shars directly? The tube is a good idea as well.Received my "undersize" ER32 collets from SHARS: they look good, have the SHARS logo (and size range!) engraved on each one. I found a larger box and now have both the under- & over-size ones together:
The 1, 1.5 & 2mm I got "directly" from SHARS via Discount_Machine on eBay. The 21, 22, 23, 24 & 25mm I got 2 years ago from who is now GBJ-1, also on eBay. The over-size collets are shorter due to their internal diameter, but work perfectly; they also saved me from buying the significantly larger body ER40 chucks & more collets (but then, although ER40 officially goes up to 26mm, you can buy them up to 32mm on eBay).I know exactly what you mean by the marks being too small. I bought a set of share er-16 from a pawn shop and I need a magnifying glass to confirm they were Shars. Those er-32 look great. Did you buy them through amazon or shars directly? The tube is a good idea as well.
Thank you.The 1, 1.5 & 2mm I got "directly" from SHARS via Discount_Machine on eBay. The 21, 22, 23, 24 & 25mm I got 2 years ago from who is now GBJ-1, also on eBay. The over-size collets are shorter due to their internal diameter, but work perfectly; they also saved me from buying the significantly larger body ER40 chucks & more collets (but then, although ER40 officially goes up to 26mm, you can buy them up to 32mm on eBay).
