True, but these Yuasa 'labeled' rotary tables are now made in Taiwan. Across the board Taiwan and China are cheaping out on these rotary tables. Cutting features and going cheap. This is the third I purchased recently...Yuasa makes good stuff.
Too bad, I was under the impression Taiwan manufacturers were striving to be top quality producers.True, but these Yuasa 'labeled' rotary tables are now made in Taiwan. Across the board Taiwan and China are cheaping out on these rotary tables. Cutting features and going cheap. This is the third I purchased recently...
8" Vertex (Taiwan) - 6 T slots reduced to 3, cheaped out on the dial a new overlapping style that's more difficult to read. Top ball oiler gone. It didn't look like it had a hardened center taper. Doesn't come close to the previous model, returned.
8" Sound Bend (China) - Wow horrible, shaft so bent or machined poorly that it wobbled like a cartoon wheel and jammed. Non-standard T slots e.g. nobody on earth makes a T nut that fits it, returned.
10" Yuasa (Tawian) - Top ball oiler gone. Flip cap oilers gone, replaced with ball oilers, even though they still show the flip cap oilers on websites and in Yuasa's catalog. Cheaped out on the dial, it has the new overlapping style which is harder to read vs the previous dial which butted together flush. That said fit and finish much better than the above two and the crank shaft turns quite straight and true. Very little backlash, about 1.5 clicks on the dial. Both the catalog and websights (MSC) have the T slot dimensions wrong, they are big honker .55 inch wide T slots (14mm).
yep, knew it was for the bedding.I’m afraid I have bad news: mice don’t eat paper products, they shred them up and carry the shreds off to use as bedding for their babies.
More bad news: my pest guy tells me that rodents can squeeze themselves to gaps as small as 1/4” (apparently their skulls are flexible or something). Best thing to do is “caulk” (like they caulked ship planking with oakum) gaps around pipes, siding, etc. with steel wool.
Oh, and they’ll run through those open garage doors faster than you can see.
Just about the size of the trap in the garage . They squeeze in but not out .
have you seen the new snap traps, plastic pad. I use dog food, I wire it in, so they can't get it out. My old traps were really scummy, only two metal ones left. I like them so far, but we'll see. I haven't caught any yet since I put them out. Last year I had a bunch with in the first two days.Don't trust those traps. Old fashioned snap trap, with a metal trigger for me. Stuff chunky peanut butter in the curl of the trigger, so they have to work at it, not delicately lick it clean. Gets them every time. And they are dead. Reuse the trap! The other mice don't care, renew the bait if necessary. Put several of them next to each other, so if they trigger one trap and are lucky, they land on the other trap, which will do the job. Do that for a week or so, and the problem is gone. Well gone for the season maybe. Seal up those gaps, that's how they get in.
The plastic pads jobs I tried were garbage. They wear out at the trigger point and become useless. Designed for a couple uses, in my opinion. The metal ones will last as long as you can stand them... I do replace mine when they get nasty enough. I now handle them with rubber gloves, no need to pick up some disease from splatted mice. Wearing those thin rubber gloves does make them interesting to set though . My wife would just as soon chuck them with the mouse still in them. I just release the trap over the trash can and it falls in. Then bait it again. If there's no evidence of mice for a week, and no trap action, I put them away until next time.have you seen the new snap traps, plastic pad. I use dog food, I wire it in, so they can't get it out. My old traps were really scummy, only two metal ones left. I like them so far, but we'll see. I haven't caught any yet since I put them out. Last year I had a bunch with in the first two days.
edit: oh geez, just looked them up on amazon, they don't require bait, the plastic is scented. yea, that can't work... dog food it is.
Amazon.com
www.amazon.com
I'd agree it's a seasonal thing. They move in for the winter, it's generally warmer and it's sheltered. Around here there's no snakes active during the winter.Yep against the wall. I would love to have snakes to eat them, but most are in the winter and snakes take too long to digest each one.
