- Dec 26, 2015
- 2,155
Read the attached before you decide between the two types of collet chucks. Also attached is my curated list of other tools and accessories you'll be considering at some point. And most newbies have fits getting down good parting operations, so I'm attaching a writeup on that topic for your reading enjoyment.Nice setup... yes, I think a collet chuck will be in my sights in the future for sure... not sure 5C or ER40... I have heard about those dynamics you mention... ER collets needing more grip on the part where as 5C can grip very little... as well as a bit safer and easier to get close to the chuck.. which I have done with a very conscious effort to keep an eye on my saddle, cutter and fingers.
Hard to tell from the last pic, but that's about as large of a item I would turn. That's also a pretty nice looking collet wrench.
I've resisted making commentary on your "which lathe" quandary thus far, but thought I'd chime in with a few comments. "Fit and Finish" doesn't capture the difference between Taiwan and mainland Chinese equipment. Both employ soft and crumbly body filler to smooth out the castings which will break away when hit with something hard leaving a nasty scar. The paint used in both situations is pretty crappy also and is prone to chipping under normal working conditions. So the "Finish" part is not a lot different, and, so much to the ridicule of many here, I strip down to bare castings and apply industrial coatings - even on equipment from Taiwan. I don't recommend you consider this unless you have the necessary mechanical aptitude and perfectionist tendencies.
The Taiwanese equipment from PM is certainly better quality - the cast iron is better quality, the gears in the head are hardened, the bearings are much high quality, the way surfaces are more precise, etc. But the Taiwanese equipment isn't German or Swiss level either - the gibs are pretty rough and just grossly fitted, some of the tapped holes are done by hand, and the factory makes an occassional mistake in handwheel markings, mis-marked gears, etc. So don't expect perfection for the extra $$.
I won't put an 800 pound 1236T on a roll-around tool box and expect to do precision work with it. That machine deserves a solid base to stay aligned. I haven't seen the subject of motor size/HP come up in this thread, and I have no experience with the 1228, but my guess is the 1236T will support material removal rates twice that of a 1228 due to the motor and rigidity differences.
If you're actually thinking this is a decision on a "trainer" lathe, one to be used to learn on and upgrade later, then maybe resale value comes into the decision - my guess is there's more used machine residual value in a Taiwanese lathe than one from the mainland.
Before getting my 1340GT I had an Emco V-10P - outstanding small lathe made in Switzerland. I migrated to the 1340 to get a machine with more capacity and power. But you might consider the following lathe. I have no affiliation, not do I know the true condition, but an Emco holds value and is every bit a toolroom quality machine.
Emco Maximat Super 11 lathe Imperial 115 VAC Complete / many accessories | eBay
Emco 3 jaw scroll chuck with two sets of jaws & Emco key. Emco Steady rest. Emco Follower rest. Emco 5C drawbar. Emco MT5 to 5C adapter. Emco MT5 dead center. Emco D1-4 spindle/chuck install wrench. Emco MT2 dead center.
www.ebay.com
Hope this helps
David
