You might also look at the Easson, I use the 12B on my lathe and it works very well, no issues with glare. Quite a few people have ordered them from Machine DRO in the UK, ships by air and arrives within a week. The display has 3 axis inputs, so I use the 3rd scale on my tailstock (Z1), but you can also get it with 2 scales. The magnetic scales are an easier install as to alignment and bulk, and the price is not much more than glass. If ordering you will want to upgrade the X axis to a 1 micron read head, the scales are all the same. The exchange rate is very favorable, and you do not pay VAT, shipping is about $70, the 1 micron head upgrade is around $30. So £550 works out to around $500, so figure around $600-650 for a 3 axis with magnetic scales. You can download the manual for features, it has soft keys which change based on the menu, you can change the display colors to your preference.
Wide Range of lathe Digital Readouts DRO Packages with Magnetic Encoders
www.machine-dro.co.uk
3 Axis Easson ES-12B LCD graphic digital readout package with three magnetic encoders. The encoders offer a very compact profile size and can be cut to length to custom fit the machine being installed. The package is suitable for mills up to Bridgeport 42" sized machines or 30" between centre...
