As long as you stick to black powder cartridges, there is no need to use a high strength steel for the receiver. Do yourself a favor and use an easy to machine mild steel and case harden it when it is finished. There is a lot of difficult machining in a receiver and the easier the steel is to cut, the better.
Tom
That's really good advice, from TomG especially if your relatively new to machining. The only thing I would add, is stamp the barrel and possibly the action with the words for Black Powder Only. Eventually someone else may acquire your firearm and without that caveat could easily put modern loadings with white or nitro powder loads through it. No one wants a firearm to go KABOOM. The risk with modern mild steels is much less than in times of old, but better safe than sorry.
Harry.
I was thinking about using smokless powder. Black powder is so dirty!
I'm not real familiar with 8620, but i've cut quite a bit of 4140 and 4340.
I don't think I would call 4140 mild steel. Definitley not 4340. They arn't
tool steel but they are tough!! Plus they machine good.
I am still in reasearch mode now and a buddy uses maybe 30000 lbs of
4140 a year so a 3 inch dia bar end 8 inches long is cheap.
Hense, I'm leaning toward 4140. But not if it's not the right material.
As far as difficulty in machining, I plan on calling in a few favors and
maybe oweing a few by the time I get done, I do field service on CNC's
for a living so I have access to lots of other peoples stuff. By the time I
mooche a bar end here and 45 minutes on a wire EDM for the ejector slot
there, then pay back all the favors, I could have most likely have bought
a gun.
But buying one would take all the fun out of it.
However I found 2 at a gun show last weekend, a 45/70 Pedersoli saddle
gun for $800.00 and an Armii? Quigley 45/110 for $1250.00 Figured better
get out of there before I bought one.
Anyway, keep the advice and support coming. I really appreciate it!!
Thanks guys
Itt
