- May 27, 2016
- 3,477
Thanks much for that.According to the Wikipedia entry for X-ray fluorescence, the mechanism is as follows: The incident photon excites an inner-shell electron and as a result it is ejected from the atom. An outer-shell electron drops down into the lower orbital and emits another x-ray due to the energy change. This secondary photon's energy is characteristic of the atom, and of which shell it came from.
If one electron is ejected from the atom, only one electron is needed to refill the vacancy and just one photon will be emitted as a result. So far I haven't found any discussion regarding the possibility of a gamma ray ejecting more than one electron from a single atom. That doesn't mean it can't happen -- unless there's some quantum-mechanical reason for it. I note that photons, just like electrons, have momentum (p = E/c): but can one photon "share" its momentum among multiple electrons? Momentum has to be conserved......and it's a vector.....and what about the possibility of multiple electron-hopping events as the electron "hole" moves from orbital to orbital? Now my head is starting to hurt
But in a practical sense I don't think it is an issue. There's no reason to believe that if multiple photons can come from a single atom that they all are emitted in the same direction, so "pileup" due to that is quite unlikely, if it's even possible.
I find it interesting that an inner shell electron gets hit first. I thought the outer shell electrons took the least energy to shake loose.
Don't worry about head-hurting stuff. The apparently temporary existence of the internal bits with 2/3 charges, up, down, strange, etc will take it to migrane level. Charmed quarks they may be, but the Quantum Standard Model, fairy story though it may be, is 10 decimal places accurate.
I did not think all the energies would be emitted in the same direction. I did just wonder if an excitation with more than enough energy to account for them all, would provoke the whole lot to come out, maybe not together, but all within a reasonable interval.
Head-hurting stuff would include..
Bell's Inequality.
The Delayed Choice Quantum Eraser - Sabine Hossenfelder
Young's Double-Slit Experiment. - (Lots and Lots of stuff on that).
