As a follow-up to the discussion regarding the Radiacode, I need to say that it is really inexpensive for what it does. The next-closest I found, an offering from Gamma Spectacular, is about $1300. It uses a PC or Mac so not as portable as the Radiacode.
One little detail that is especially relevant for our effort is that the energy resolution specifications are based on a much-higher energy reference -- Cs-137, which emits gammas @660Kev. A good NaI scintillator detector can achieve around 7.5% at that energy. At lower energies the resolution goes down. At 6Kev it's substantially worse than that. Other scintillator materials can perform much better than that, but they cost MUCH more.
Silicon PIN diode detectors can perform much better at lower energies, so that's why our efforts have centered around them. Unfortunately, the large 10x10 detector that was sold as part of a ~$100 geiger counter is no longer available so I've been exploring alternatives. The best results, in terms of energy resolution, that I have seen for PIN detectors, would be great for our needs but costwise are out of the reach of hobbyists. I found some smaller ( 3x3mm) detectors that are pretty reasonable, pricewise, and one of them already has been used in a simple "demo" system -- see here. Improved electronics, along with (likely) a Peltier cooler, could get us where we want to be.
The PIN detector used in the demo is a Hamamatsu S1223. Newark sells them for $11 or ~$19, depending on the detector area. The more-expensive one has about twice the area, at 13mm^2, and is one of the ones I bought to play with (the other is an even cheaper, smaller-area PIN diode sold by Osram). So definitely in an affordable range for folks like us. Some fairly good electronics will be needed as well, but I think there are a number of folks on this forum who are well-qualified to contribute in this regard.
There is one big unknown regarding the use of PIN detectors that weren't specifically designed to function as x ray detectors -- and that is, of course, how well they will work in that application. The link I included shows that the S1223 can at least detect x rays but it's not clear (yet) if its energy resolution and its sensitivity will be sufficient. There's only one way to find out......and I'm working on that!
HB
HB
