- May 27, 2016
- 3,477
This relationship is something I am also convinced about, even though I thought it was strictly only true of square-wave pulses, and triangular ones comprised of two triangles put together. I like it because it saves a forty bucks ADC.Looking at it from a theoretical standpoint, the Laplace Transform of A*f(t) = A*F(s). By extension if we use a linear filter we know the output is proportional to the amplitude of the input. That won't be a surprise to anyone who has spent any time at all in the vicinity of this thread.
I don't think it is a stretch to assume that the pulse height coming out of a TIA or charge amplifier being tickled by an x-ray generated event also is proportional to the total energy of the pulse, so I'm pretty confident that the amplitude of a stretched-out version of the pulse will be as well. The pulse height of our low-pass filtered signal won't be anywhere near the height of an unfiltered pulse, but that's something that can easily be addressed with some post-filter amplification.
Area = 1/2 base x height. If we make the base longer, the height gets less. That's OK, because we can either start with more than we need, or give it some gain after, or a bit of both.
As it happens, I already bought the ADC, so I decided to push it to to deliver to it's limit. Pulses from my TIA design can also be stretched with a filter afterward, if one decides to exploit the built-in audio channels in the computer end.
One thought I had about pulse stretching, was the need to block new incoming pulses while the filter is doing it's job. For this to work, we either trigger a window to keep the pulse exclusive, until it's over, or reject pulses that have too much content. This situation is also there, even without pulse stretching, but the shorter capture time leaves more for others to be captured, hopefully increasing the count. OR .. we just wait a bit longer for more count.
