- Mar 25, 2013
- 5,220
I am working on the trunnion index marks. I have calculated the location of marks for a .032 thick piece of brass screwed to the trunnion. There is .396" between markings at 15 deg of rotation. I can scribe the lines on my mill but I can't engrave numbers. Stamping will deform it. Does anybody have engraving capability to add the deg numbers? (0, 15, 30, 45, 60, 75, 90) It would be on a flat sheet of brass about 3" long.
You know, in playing with my device, I can see that the index marks on the trunnion will be hidden by the spindle index when in the vertical 90 deg position. Placement of markings is limited by the slot for the gear. I am wondering if putting the index marks on the end cap for the aux base would be a better way to go? This end cap could be thicker than .250 to accommodate engraving. This would be much more visible in use and you could put the marks anywhere on the circumference. This cap could be keyed with a 1/8 dowel pin to assure correct alignment. This would be a lot like making a graduated dial.
