- Mar 25, 2013
- 5,222
I finished my method of retaining the spindle. It turns very smoothly. Its basically a big washer with an Oillite bushing.
I worked on the worm mount today. Used the rotary table to trepan a hole then used the boring head.
There is damn little material between the holes. I am wondering if I should thin out the material around the 1" hole so it can flex more there to prevent flexing concentrated at that thin web?
This part really needs to be made of steel, but I had a hard enough time getting a 3" hole in 6061! If you make this use steel. Maybe worth your time to get a hole plasma/laser cut?
