- Jan 10, 2019
- 1,220
I have never dealt with a project requiring so much precision on so many levels. There are so many surfaces that need to be within a fraction of a millimeter for the router to work well. Any misalignment will not only produce objects that are "off a bit", but can also cause the servos to bind up if they have to fight misalignment. That last bit has really been beating me up. What doesn't help is not having $10,000 worth of metrology equipment to do it right, never mind much faster and more easily. On top of this is the concern that because I bought the ball screws and linear guides used... it begs the question: why it was removed from equipment? Was the equipment being recycled, or was it because there was a problem with the bearings or drive screws? Indeed, things have made strange noises from time to time, then it all goes back to working fine - a very mixed blessing.
On top of this is buying a CAM package that's designed for home hobbyists, and while that's helpful up front, it suggests that it may be limited once venturing out of the children's pool. Already it's doing some strange things, mostly seemingly unnecessary moves across the work and then back again. I've been in contact with the support staff about its difficulty at machine a simple slot. There is virtually no documentation, so I pester Support to explain everything - that's what they get for having no manual. Anyway, I'm considering returning it and buying a serious CAM package, which is very much at the deep end of the adult's pool, where instead of it setting most variables for you, it lets you do Everything, which means the user has to know what they're doing...
Lastly is the annoying little voice that's been saying, "if you made the dust shoe how you normally would, you'd be done weeks ago." Yes, and I wouldn't have a working router or know how to run the software...
