- Jan 10, 2019
- 1,220
The 19 mm aluminum tool plate is here. By the time the drill program was about to be run, I set something wrong and it was just "cutting air" way above the part. That's the scary thing about this stuff, kinda like flying a plane. It's fun and all, but one tiny screw-up, one overlooked factor, or a brief lack of attention, can cause things to go very wrong in a hurry. Granted that there's a feed override control - and an Emergency Stop, but I've found when I start pushing to get something done toward the end of the day is when I make mistakes, so everything was shut down and I'll try again tomorrow.
Once it's bolted to the granite, next is deciding what bolt pattern to use for attaching work to this plate. I saw one setup where they used 1/2-13 thread, which seemed huge, until seeing that fit hold-down clamps from a standard milling machine set - that's clever. Another video showed using shoulder bolts, specifically the type with no head (I'm calling them "shoulder pins"). The plate might be threaded 2/3 of the way through, and the upper third reamed for a snug fit on the shoulder. This would provide very accurate reference points to slide parts up against. A combination of the two patterns could be even better. The more I think about this the more I like it.
Regarding the above holes: blind or through-hole? Threaded through holes are easier to deal with during fabrication... except that once done, if any coolant or lubricant is applied, it can get in the holes and sit there forever between the aluminum and granite, probably doing bad things. To coin a phrase I've been hearing lately, "this is not optimal." Blind holes, on the other hand, keep fluids and chips from getting stuck between the plate and granite, which seems like a good thing. They'll both still pile up at the bottom of the holes, but at least there's a chance they can be removed with compressed air or a vacuum. Just have to decide on the size of shoulder bolts to use. Not sure there's any advantage to using small one, so maybe 12 mm shoulder... pins, but this is subject to change at any time.
