- Jan 10, 2019
- 1,220
The second Y servo assembly is complete. Unlike the first, reassembling the ball nut went much faster - having learned how the hard way. Like the first assembly though, both finished bearings were stiffer than before disassembly. As mentioned previously, they're anti-backlash units, with two bearing sub-assemblies that push against each other to virtually eliminate backlash. Preload between the bearings is set with shims between the units, which are then locked in place. For some reason, the shims act as if they're slightly too thick - go figure. The worry about too much friction caused me to carefully lap a fraction of a millimeter off each, and now they turn about as easy as before. Yes, someday I may find out what I did wrong, and then thicker shims might be needed, but that's a problem for Future Me...
For fun, I connected one of the Y assemblies to the controller just to see it move. I'd already run one motor on its own so wasn't expecting much... hah! As soon as I commanded a move, it started banging back and forth and making a big fuss. That made it clear that the Teknic (servo manufacturer) advice to tune each servo in the environment where it'll be used isn't just a suggestion. Ran the tuning software and all is well.
Next up? Probably the moving Z axis assembly. I can't start on the X axis components because the final size of the X axis granite beam is still an unknown (file this under "work with what you can get). Speaking of that, tomorrow I'll have words with the boneheads at the granite fabrication business. Either they'll be shamed into getting on with it, or I'll look elsewhere. There's also a dashcam to install in our car. Been watching a bunch of videos on that, weighing doing it myself versus paying $250 to have someone else do so, though it irks me to pay the same for installation as for the camera itself!
