- Nov 24, 2014
- 3,297
Suggestions:
Put a thrust bearing w/ washers between the sector arms and the spring to decouple torque. It looks like you have plenty of shaft length to accommodate a TB.
I have used an O-ring, stretched over the gap of a thrust bearing w/ washers to keep swarf out. It's not an idiot proof seal but it's cheap, simple and I've had zero problems using it in similar situations.
I've never used the wavy washer stack springs that you picture. My go to would be Bellville spring washers because force is easily adjustable as required. The wavy washer stack looks like a swarf trap. Not a problem with Bellevilles.
Would the sector arms pictured work if you decoupled the torque?
