- Dec 26, 2015
- 2,173
Maybe not optimal, but then how often do you have to change the speed enough on a single setup that you would need to change the speed range. Still better than a gear box. At least it should be reasonably quiet. Why would you have liked this on the 833TV but not on the 940 except that the 833 is Taiwanese?
I do a lot of work in stainless and 4140, so I need low end torque for tapping and drilling. It would be a real PITA to have to change belt positions in the middle of machining a part that was otherwise fully automated via automatic tool changes. If your standing there changing tools with a drawbar hammer between operations, then of course a belt change is a minor irritant.
The spindle James is putting on his Grizzly Is 4 pole, or two-speed, so it can run at slower speeds without giving up so much torque using a sensor less vector VFD. Some specs are here.
Have a look at this video showing that spindle working in steel.
As for my comment on the 833, let me clarify. The 833TV most obvious drawback is lack of low end torque because at 100 RPM the VFD is putting out maybe 10Hz. So a two position belt would have been ideal on that machine for use as a manual mill. The fact that the 940V has a two position belt is great - provided its used as a manual mill. I’m glad PM didn’t try to span 50-3200 RPM without a belt change on the 940V, like they do on the 833TV. But both machines could just as easily been done with two-speed motors and no belt change to get similar benefit (but this would probably cost more). Not a big deal for manual machining to change belts, but pretty disruptive to change belts in a series of CNC operations that include an ATC.
I‘m not in disagreement with you about the utility of the 940V given your desire to do as little as possible for the conversion. It looks ideal, assuming the right things have been done with motor, VFD, spindle bearings for 5K RPM duty. Being from mainland China I am a bit suspicious. But as Mark points out, it does have 3 year warranty. Do think about a power drawbar - I spent the better part of a week on a Tormach without a PDB and it was excruciating.
In my case, I’m open to more substantial conversion efforts to attain perfection. Can the “Best & Jacobs full Custom CNC” be that far off? LOL
