- Mar 16, 2017
- 149
Reviewing the information, it probably comes down to how much travel and drive system speed you need and less so about Chinese vs. Taiwan. Another factor would be available kits if you do not plan (or have the ability) to mill the parts to convert to CNC. I would probably go with the PM-940V-BASICw/HRDWYS, it is basically setup for conversion to CNC, it is a 2 speed Low 100-1640 RPM, High 350-5000 RPM variable speed head. Probably beyond 5000-6000 RPM the bearing would need to be switched out and change the pulley ratios. It has an option for hardened beds, you would want to add an automatic oiler. Seems to be a number of CNC kits available, this was also can include Clear Path or DMM servos. I had looked into DMM servos in the past and they have some very nice drives/controllers. If going with the PM-833, the TV seems to be a more logical choice for reliability and convert the head to a 2 speed pulley belt system. In both mills you are already starting out with a VFD rated motor and drive, the downside would be if there is any provision for interfacing its control with a CNC system. You could interface a control relay to turn on/off the drive. You also could check if any of the CNC retrofit vendors have something in the works for the PM-833TV. Both mills are close to the same price, but for a CNC conversion project I think the PM-940V has a bit more going for it.
PM 940M CNC conversion Kits
www.arizonacnckits.com
Mark,
Somehow I seemed to miss the 940V completely. I swear it wasn't on their website this morning. This looks like it could be a good option. I was leaning toward the 940M but didn't like the gearbox so I was thinking the 833TV but this changes things. I'm not sure how they do the variable speed on the 940V though. The specs say it is a single phase motor but that could be a misprint held over from the 940M specs. Hopefully it is actually a 3 phase motor. If the column and the bed is the same as the 940M, the ArizonaCNCKit conversion would work. I'll call PM in the morning and find out more. ArizonaCNCKits is suppoedly coming out with a belt drive conversion for the 940M as well but he hasn't started on it yet. I believe it will be a 2 speed unit which would be great. I already have a sherline mill set up for CNC with a Centroid Acorn board so all I would need to do is put in the appropriate stepper or server motors and bigger motor drivers and I will be set. The electronics are the easy part for me. I know nothing about ball screws and nuts so that is why I am looking for that as a kit.
Paul
