- Dec 26, 2015
- 2,155
You said a couple of times during the video that your column is “good“. In fact, the column is out of tram by 1.5 thousandths of nod over the 3-5 inches of head travel, so it is not in tram. We could debate whether 1.5 thousand over the 3-5 inches you moved the head is “good enough“ but for the kind of work I do that is not accurate enough and would certainly be considered out of tram on something like a Tormach machine. You should also be checking tilt in addition to nod by indicating to the side-face of your 2-4-6 block. To correct the 1.5 thousandths nod error over the 3-4” inches of head travel you would need to shim the column to base connection.
Probably more concerning is the fact that the quill movement and the head movement on the column are not coplanar to each other - they diverge by 5 thousandths over the 3” travel of the quill. Imagine drilling through a 3” block of aluminum using the quill - the position of the top and bottom of the hole will differ by 0.005” front to back. Is that “good enough”? Not in my world, but you may be less demanding. I’ve never seen a specification from the factory as to what they think is acceptable on this head-versus-quill movement correlation. Again, check tilt in addition to nod. The correction for this quill nod travel error is to shim or scrape the connection between the head and column.
