- Mar 22, 2013
- 511
So I think what they are saying is that:
1. The runout is probably within spec, but what you are measuring is coming from the difference in the test bar diameter and the bore diameter the Top of the spindle. (The top of the spindle dimension range is 24.125-24.145mm / .9498-.9506")
2. You had a problem with our drill chucks, which I know are a bit smaller, usually those measure around .947" - .948" at the top. R8 collets are usually .9485-.9498 when I have measured over the years.
3. They said to send you a new drawbar and try that first, if the drawbar is distorted it could be pushing it off to the side at the top of the bore there.
4. We will figure it out, it may not be what we / I thought at first, but we will get it worked out!
What is the diameter measurement of that test bar at the top of the R8?
